I thought that about the stain. Most of the gaps are fairly small. It was just filling that bit where it's broken off. I did see that Sikkens do an external wood filler but seems daft buying something for the small amount i need.
I've also found a split forming on the bottom of one stile. Going to have to pull that off and re-glue it on. Hopefully it'll go back alright. Think it's been knocked because maneuvering the gate now it's assembled has been tricky in a fairly small work area!
Good to know about the Sikkens, think it cost £95 for the 2 products! We'd prefer more of a matt/satin finish so i might just use the HLS plus and see how it looks after 2 coats and how far the tub will go. If i can get a third coat out of the tub i'll use that and send the Filter 7 back. If it looks like it won't make it i'll use the Filter 7.
Also realised i'll need new hinges. The existing hinges (bottom one anyway) grip around the stile. Because this will be boarded there isn't going to be the space to do so. Because i didn't think and have made the new gate the same size, i'll need a new hinge which still holds the gate away from the post rather than a more traditional hinge.
Any good websites for fixings? Given it's an old house it might be nice to have something a little more traditional.
Also looking at that picture, i'm fairly sure my next job is going to be painting the fence as it's going to look dark with a light oak stain and dark brown fencing
i HATE painting.
