My new one is stock timing but that's a good idea. There are timing marks on mine but I couldn't decide what way up they wentDogbreath said:I guess you aren't going to go for a funky vernier sprocket to time your new cam in..
I always mark a tooth on the crank sprocket and the adjacent tooth on the cam sprocket , that way you don't have to rely on setting engine at TDC to get it accurate. Do it with a center punch and it won't rub off either.
Depends on the cam. If it's a fast road jobbie then don't bother, it's so much easier to just use the standard wheel and it's accurate enough. If you have a race cam then it might have different timing to the stock cam. If optimum horsepower is at stake then use a vernier but most cams are ground on a stock dowel anyway and modern grinding tolerances are so good you'll probably find it's so close it wasn't worth the expense and time spent timing it insaitrix said:Sorry Jonny for the little OT, but are vernier sprockets worthit if I decide to change the cam in mine?
Jonny69 said:
[huzeeee] said:Looks good mate, are you going to take out the ports aswell for better flow, surley even if you just give them a polish it will make a god bit of difference?
penski said:You shouldn't polish the inlet ports; it can cause the AFM to separate
*n
Not going to be opening the ports up at all because the valves are quite small and it won't be of any benefit. No point having a large flow area squeezing into a small area. The main pinch point is across the tops of the valve guides so I am going to machine them down if I can hold them tight enough in the chuck. I have already run a file down the ports and knocked the flashing off.[huzeeee] said:Looks good mate, are you going to take out the ports aswell for better flow, surley even if you just give them a polish it will make a god bit of difference? If i were you i would grind the conrods aswell, grind the casting flash off, on most rods you can also take a fair whack off the cap. Then a polish and ballenced end to end is a process which you could do yourself with an accurate set of scales.
