With a new shell that would be a really tempting project. Fixing acres of rust is soul destroying. All you have to do is clean up some old parts and screw it back together, hey presto, solid new Sprite.
I was looking at getting an Austin A35 and using Sprite/Midget running gear but the Pop turned up instead. On the 1275 engine you can use a lot of Metro parts including the turbo head and manifolds, this was going to be my plan for that car and it would make a really lively little sportscar in a Sprite. You can also steal the bigger disc brakes off one of the bigger cars as well, but I forget which one it is.
With a bit of research there are loads of parts out there that swap on or go on with a bit of minor modification and it can really liven up the driving experience. If you don't get too serious with things (ie don't bite off more than you can chew) you won't lose direction in the project and you'll be having fun in no time
Then it is rolling road time, lol.
