SB118 said:Or you can just wack a cordless drill on the other end of the valveSOOooo much easier
Battery was flatSB118 said:Or you can just wack a cordless drill on the other end of the valveSOOooo much easier
Just did a visual check because the engine ran nice and smoothly before I stripped it with no noises or vibrations, all the trouble was with the top end. There are shell bearings in the crank which I don't think are original and they don't show much sign of wear so maybe it was rebuilt at one point, plus there's no play and it moves with about the amount of resistance I would expect so I think all is ok.[huzeeee] said:What a big stroke you have thereProgress look fun atm, i love getting the bulk of the engine made, its really satisfying. If you dont mind me asking, did you measure the crank journals to check if they are within the tolerances? Or is the engine that old that no tolerances exist anymore?
Jonny69 said:No chance! It might fly apart quite spectacularly but I don't want my feet next to it when it happens![]()
