Hi All, I was going to upgrade my old PC but after watching a how to build a PC on youtube have decided to build from scratch, I am building with a tight budget and have bought some 2nd hand parts aswell as new, so far I have:
K380 Coolermaster case
Asus M5A97 LE R2.0 motherboard
AMD FX4100 processor
Seagate Barracuda 750GB hdd
Samsung 24x dvd writer
Coolermaster Real Power M520 Modular ATX PSU
G Skill RipJawz X 1866MHz RAM 8GB (2x4GB)
Cooler Master Sickleflow 120mm fan
What do you all think of the parts so far? and I believe I will need a graphics card as I think the CPU and motherboard do not have integrated graphics, is this correct?
If so what graphics card would you recommend? I was looking at EVGA Geforce GT 520 1GB, would this be a good choice or Asus AMD Radeon HD 6450?
Is there any other advice you would give for someone attempting a 1st build, I know about touching the case frequently to avoid static.
Many Thanks in advance
