Hello all, well this is my first time building my own sytem but im extremely confident i can build it easy enough, however i could use some advice on some parts.
Heres what i was planing on ordering.
Processor: qx6700 (for sure) oem version, no difference from retail except no fan right?
GPU: 2x 8800 gtx (for sure) probably leadtek as they are cheapest on here or should i go for another brand?
Motherboard: EVGA 680i (for sure)
Memory: This is a part im not to sure on, will pc 6400 be good enough? If so what make, Corsair 2GB DDR2 XMS2 Dominator PC2-6400C4 TwinX (2x1GB)? or say GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC)? Will 8500 type give a performance gain to warrant the price difference?
Harddrive: Western Digital Raptor 150GB WD1500ADFD 10,000RPM SATA 16MB Cache - OEM (for sure) will probably add a second for raid 0 further down the line.
Case: Im not to sure on this either, i want a case with good cooling and great looks and not to loud and dont want to spend all that much, £150ish tops, maybe a bit more if the need arises, preferably closer to £100 though
. I was thinking Thermaltake VA8003BWS Armour Super Tower - Black (perhaps kandalf equivalent) is it a good case? i should also add i kinda like the style of lian-li cases, but what 1 for this set up?
Cpu Cooler: Was thinking, Tuniq Tower 120 CPU Cooler, is this good enough or is there something else i should consider?
PSU: I was thinking, Enermax Galaxy 1000w, or should i consider something else?
EDIT: Sound card will Creative Sound Blaster X-Fi Fatal1ty FPS Edition
EDIT2: what dvd drive?
Thanks in advance
. I was thinking Thermaltake VA8003BWS Armour Super Tower - Black (perhaps kandalf equivalent) is it a good case? i should also add i kinda like the style of lian-li cases, but what 1 for this set up?Cpu Cooler: Was thinking, Tuniq Tower 120 CPU Cooler, is this good enough or is there something else i should consider?
Thanks in advance
althought it is a dust magnet
and memory im not sure in same boat myself considering for my new system, a lot of ppl recommend and buy the geil because its good stuff and cheaper, but then again i like the look of the dominators lol they must be better for that price surely??
