Fireskull said:http://forums.overclockers.co.uk/showthread.php?t=17649249 read that about the eclipse and the tuniq
Thanks
harris1986 said:sorry if it has already been asked but what will you be mainly using the rig for? also i'd advise against the fatal1ty sound card for the time being as there currently aren't many games that make use of it, the xfi xtreme music does just as good a job!
* i can't help but feel you are living beyond your needs with that spec!
Massive Attack said:just wondering how you are going to power 2 8800gtxs, 4x6pin pci-e connectors?
Solaris said:crt dude............one question.......
Do you own a bank? Or a munny tree?
I wish I could afford a rig that good.....can I worship it as my god when its finished?
crtdude said:Processor:[/B] qx6700 (for sure) oem version, no difference from retail except no fan right?
EDIT2: what dvd drive?
jcb33 said:I spent £2000 on a top of the range system earlier this year, runs everything on the market perfectly at high resolutions and max details, however I then got an identicle system for £400 6 months later, If you take my avice, I would suggest you build a cheaper PC 5 times rather than just go all out on one that will depreciate very quickly and become out of date technology, its just not worth it
Fireskull said:Yea it dont look the like enermax has 4 x pcie power, your going to need the http://www.overclockers.co.uk/showproduct.php?prodid=CA-010-TG tagan instead mate.
Smurfy said:Quoted for truth, im currently experimenting with the idea of living 6 months behind the times, despite feirce tempation im holding off the constant urge to spend my money on a sli 8800 GTX machine.
Although my brother doesn't agree, he used to get all my old parts.
crtdude said:Well, i would consider myself a hardcore gamer and i want everything to run as fast as it can at high rez on full details with any game i throw at it, i was going to get the x6800 but seeing as the quad can be had for just a little higher i figured id get that instead and oc it a little so it performse as good/better than the x6800 in current games and then im set for when developers start utilizing the technology, several games will be taking advantage of it next year which i intend to play with full detail.
also im the kinda guy that wants/needs the best at the time![]()
