Bumper Removal Problem - Real Rusty Bolt
19 Jan 2003
Bristol, UK
I wanna take the Rover off the bumper so I can fit all of the front end properly as it's a little scew-wiff.
Now this in itself is an easy job, just a load of screws, nuts and bolts.
All of them come out a doddle except one, it's behind the front numberplate. Rusted right up and I just cannot get any sort of grip on it at all.
Any ideas?
You mean you want to take the bumper off the Rover not the otherway around ;):D
Best thing to do is soak what ever you're trying to undo in WD40 makes life easier.
Don't you have a socket set?
Of course I do but the bolt is just so rusty I cannot grip it, I hammered on a smaller socket and the same just happenes again.
Can you flatten the sides again and just use a smaller socket?
If not then just have a hissy fit and start screaming at it.
saitrix said:
You do realise a hammer is a tool that does not turn bolts but instead just crushes them?
Lol, sorry, use the hammer to *gently* tap the bolt after using the WD40 on it - it might loosen it enough.
Failing that just whack the bolt with the hammer until it breaks off - I'm sure it won't matter if it's missing.
Did commonsense stay on your pillow this morning :p
If it breaks off how is he going to get the rest of the screw out? :p lol
There's nothing to stop the bumper coming off then though, he'll just have 1 less bolt to secure it to the car.
Hmm, good point. :p
Ok - new plan. Look underneath the driver seat for spare change, then park this Rover in a field. Walk away with the spare change and buy one with a straight bumper.
Job done.
Would be a shame if that bolt was holding one side up otherwise it'd be hanging down :p
