- 6 Jun 2011
[RXP]Andy;21436928 said:What 800 series where you thinking about? 887VA? The Cisco 887V or VA works with both ADSL2+ and VDSL.
If you where set on using Cisco equipment for home use, id personally go with the 887VA over a 1841, it also a better all in one solution. However, I believe the 1841 doesn't support the new HWIC cards for VDSL so it would require you to use a VDSL modem.
Thanks for the response. The one I was looking at was the 887VA. But then somebody else suggested a new one that is coming out called the 867VAE.
This is exactly what I thought, it would work for everything I need. ADSL2+ now and VDSL in the future. I did also have a look at the 1841 and I think you are right in what you say.
Thanks!
