Hi all. I moved into my new house about 2 months ago and had Blue Yonder installed as quickly as possible (4 meg plus a TV package). All was going well untill a few weeks ago when my speeds dropped to a now average 1.5 meg and It's now impossible for me to get an in-game (CS/TFC) ping of less that 80-120ms, whereas up untill a fortnight ago I was getting sub 20 pings on the same servers (also the same is happening if I ping jolt/google/co.uk from run>cmd).
We have just had 3-4 sets of people move into the flats above and below us (tis a big mansion type thing) so i'm wondering if they might have had BY activated and thus mine has slowed down?, or does BY not work that way (not really clued up on contention and things).
When I visit my modem i'm seeing these pretty things:
Log:
Unfortunately I have no idea what these errors are whatsoever lol. I'm wondering whether it's simply because my neighbours have now got connections going into the building or possibly it's my modem or something?. Just to clarify, my neighbours live at different adresses and have different connections etc, My connection goes straight from the modem into my onboard asus ethernet thing, previously trouble free
Edit: Just got 2 meg down on adslguide speedtest. Highest in 2 weeks.
Cheers for reading.
Log:
Code:
Time Level Description
2006-10-07 22:00:05 error BPI FLASH: The Mfg CA certificate not found!
2006-10-07 21:59:33 error BPI FLASH: The Mfg CA certificate not found!
2006-10-07 21:37:17 information Ignore SW upgrade via provisioning: same image!
2006-10-07 21:37:16 notice Interface index:4 LinkUp
2006-10-07 21:37:16 notice Interface index:3 LinkUp
2006-10-07 21:37:16 notice Interface index:2 LinkUp
2006-10-07 21:37:16 notice SNMP COLD_START(SNMP Nmaccess mode)
2006-10-07 21:37:16 notice Cable Modem Status set to Registration Complete
2006-10-07 21:37:16 information Locked Plan ID : 17 , Locked Frequency = 331000000 Hz
2006-10-07 21:37:16 information Received REG-RSP from CMTS
2006-10-07 21:37:14 information Sending Registration Request
2006-10-07 21:37:14 information Processing Configuration File
2006-10-07 21:37:01 warning ToD request sent - No Response received
2006-10-07 21:36:53 information DHCP: IP complete
2006-10-07 21:36:53 warning DHCP WARNING - Non-critical field invalid in response
2006-10-07 21:36:28 warning DHCP WARNING - Non-critical field invalid in response
2006-10-07 21:36:22 debug DHCP_coldstart() successfully
2006-10-07 21:36:08 critical No Ranging Response received -T3 time-out
2006-10-07 21:36:05 error BPI FLASH: The Mfg CA certificate not found!
2006-10-07 21:35:53 error BPI FLASH: The Mfg CA certificate not found!
2006-10-07 21:35:45 critical No Ranging Response received -T3 time-out
2006-10-07 21:35:33 critical No Ranging Response received -T3 time-out
2006-10-07 21:35:29 critical No Ranging Response received -T3 time-out
2006-10-07 21:35:28 critical No Ranging Response received -T3 time-out
2006-10-07 21:35:27 information Beginning ranging process. Initial Power= 8.00 dBmV
2006-10-07 21:35:27 information Got a map with the new UCD change count, and changed upstream parms
2006-10-07 21:35:25 information Sync recovery loop is locked
2006-10-07 21:34:33 information Scan Downstream Frequency...
2006-10-07 21:34:30 error BPI FLASH: The Mfg CA certificate not found!
.Edit: Just got 2 meg down on adslguide speedtest. Highest in 2 weeks.
Cheers for reading.
