- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Regretably you cannot install a Vertical mount with a rad/fan config in the base.Thanks.
I have the o11 dynamic at the moment but im flogging the full pc, so thinking of getting this case. But the issue i had with the o11 was that with a v-mounted gpu, i could fit fans but no rad at the bottom.
Im wanting 3 x 360 rads. Not that i need 3, I just want 3
The reply I received from our PM stated:
Code:
Hi Lee,
If you are using vertical GPU, no room for radiator. C8 has 8pcie slot, if you are taking 7pcie slot, only 33-30mm room in between.
You need to have at least 53mm with radiator and fan.
Eric
