- 11 May 2013
Been getting into this cable braiding thing, probably spending too much on it actually but one thing I've wanted to know is where others stand on braiding/re-sleeving case front panel leads?
I ask because the YouTube video I found on this never show the cables actually in place and the issue that concerned me is that the guy used heat-shrink over around 33% of the speaker, front LED and other header connector plugs.
It might look good but in my experience, limited though it is, those plugs are already very close to one another when plugged into to the MB front panel header array. I would have though two thicknesses of heat-shrink ie. two adjacent plugs is pushing it, quite literally.
Thoughts?
BTW I found that Teleios sleeving mentioned above didn't have a match for the MDPC-X yellow sleeving when I discovered I hadn't bought enough from MDPC-X. The latter are still 'reorganising' and not available for business. So, after several expensive mistakes I eventually found UK sources selling, although not quite colour matching, quality, dense weave coloured sleeving very similar to MDPC-X. Far cheaper delivery too.
The nominally 10mm braid is slightly wider than MDPC-X's purpose design SATA sleeving but seems to tighten around the flat cable just as effectively. If I'd discovered this alternative earlier I would have used it for everything but now, having carefully sleeved five SATA cables in MDPC-X sourced sleeving the not quite matched colour of this alternative would cheapen the look. So I guess I have to wait until MDPC-X stuff is available again.
I'm not sure whether I can post the link here so I won't but if you Google (UK) "dense weave matte yellow cable braiding" you'll find the supplier and other resellers.
Thoughts?
