Derek, I've braided one of those myself.
The 24 pin is easy for male, female, you might need a bit more force on the cable.
kd
I tried forcing it a bit more tonight and ended up with a couple of cuts on my thumb from where the 4 broke away from the other 20 connection
Looked in my current pc cos i thought i had another extension cable to see if it was any easier but sadly I managed to stretch the psu cable to the mobo. I nabbed the 8 pin psu extension cable and that one seems fine for removing the pins so I'll work on that one when my heatshrink arrives.
how many metres of sleeving is generally needed to do a PSU and case cables?
Will 10metres be enough?
Nils only sells stuff between certain hours now because of various time constraints. The International site does give times, and it does tend to be open then. So double check and just try again.
As for seeing products, you can preview the products on the German site to decide what you want first.
http://de.mdpc-x.com/
You'll probably have to rely on Chrome or something to translate, but yeah.
kd
Yeah, you need quite a bit... Buying pre-cabled bitfenix works out to about £100 for a full set, about the same for a braid yourself. You can buy fewer bitfenix though and not do a whole set.
kd
Cable braid guide as promised.
Not going to take credit for this, but can't remember whee I got it from.
There is some flex in sizes but these I feel are a good benchmark
Individual Wires - 3mm or 4mm
SATA Power Cable - 6mm or 3/4mm for single wires
SATA Data Cable - 6mm (Make sure it's expandable to 12mm or if you have 10mm you can try but it might be a tight fit.)
24 Pin MB ATX Connector -12 mm or 3/4mm for single wires
6 Pin PCI Express Cable - 6mm or 3/4mm for single wires
8 Pin PCI Express Cable - 6mm or 3/4mm for single wires
4 Pin For CPU - 6mm or 3mm/4mm for single wires
8 Pin For CPU - 6mm or 3mm/4mm for single wires
4 Pin Molex Power Cables - 8mm or 3/4mm for single wires
3 Pin Molex / Fan Power Cables - 5mm/4mm/3mm
