The original TRUE came with fan clips while the newer one comes with the fan holder.
I orderd a TRUE Rev C as part for build last week, came with the standard 2x fan clips...
You'll probably burn it out.
OcUK dont have these versions in stock!!!
Poly shrouds can be purchased for very little £'s if anyone with older models wants to try them out, have 2 on mine however they dont clamp on easy. And yes i failed to read your post in full, just the text above the large pic, so I apologize
Off topic, but I just had a look on Thermalright's webpage, and they have a socket LGA1160 listed, does anyone have any idea what chips are going to use this socket?
LGA1160 became LGA1156, 4 pins that did nothing (Although I remember seeing something about they caused random crashing when a zebra was within 50m ?! (Will Google around to find this again)) were removed.
