Can anyone help with SX8200 Pro M.2 installation?
14 Aug 2019
Hi,
Bottom line to the problem is that I've installed a XPG SX8200 Pro on my Asus Strix b250f Motherboard, it detects the M.2 SSD in the BIOS but is not accessible under My PC. After installing I went into the BIOS to configure the settings to allow the M.2 slot to be used. In the image I found where the setting would be I could not find the correct setting to enable the M.2 slot.
The M.2 SSD is being detected in the BIOS but I cannot find it under the usual location under This PC. I'm currently running Windows 10. I've searched everywhere for a solution but most problems occur that the M.2 SSD doesn't appear in the BIOS which mine does.
any ideas?
