I've had a look around and there doesn't appear to be too many decent options for both a wet and dry cleaner!
I'm leaning towards the
Vax 6131T as it seems to get decent reviews and my parents had a Vax previously and it was spot on!
Has anyone got one and can comment?
yea I said earlier
Good suction on my new carpets.
sucks the lino off my kitchen floor if I don't set the head to the hard floor mode.
bags for it are uber cheap on amazon and they hold quite a lot
stupidly long power cord
stupidly simple design which imo is a good thing
two seperate reservoirs inside one for clean water and one for the dirty water you suck back up (clean one only holds 4 litres or so though but the dirty one holds a lot more)
All the filters on it can be washed in warm water
looks fairly cheap but then again it is
quite bulky (4 wheels on it thought so its effortless to pull)
It's noisy. (1300watt though so I guess thats why)
Doesn't come with a rotating head thingy so won't pick up pet hair very well (some of the ones from other vax models fit though if you need one)
some people said there pump died after a week but they probably ran the pump without any water in it like tards? (they had no trouble getting a refund from amazon though)
I've not used it to shampoo my carpet but my ex has an older model thats almost identical apart from hers is purple and has a dial on the front so you can alter the motors speed and hers has a turbo pet hair head thingy.
Shes always been happy with how well it washs her carpets and as you can see from the amazon reviews the people who arent happy with it as a hoover (because they have pets) still rate it for its carpet cleaning function
