- 18 May 2009
- Expat in LA
Hey guys,
Need some serious help! My parents live in Spain, and im over visiting, and my first take is to fix the Wi-Fi that they've never had working, but need. They have a broadbandish connection I believe through their phone provider, which consists of a phone like, plugging into the provided ADSL router. At the moment, they are plugging an ethernet cable into this and straight into a laptop. This works fine and is what Im using now to type this. Not a problem! I tried everything I know to get the wireless router up and running, but nothing. 99% of the time I cant even pick up the wireless signal from the box, however, once in a while, it pops up and shows me its available. I dont know whether this is because I keep fiddling with the aerial or not though. Im never sat more than 60m away from the router though. And when it does show up, and I try and connect, it disappears faster than I can connect!
So yes, this is my problem, ive tried everything I can from reseting the router, to pressing every button on it thrice! The problem is I cant phone the provider, as they dont have anyone English speaking there to help deal with it, and although my parents speak a good standard of Spanish, its nothing technical enough to deal with this, let alone, they dont have a clue what theyre talking about most of the time anyway.
Let me give you the router details.
Its made by Comtrend I think? For Telefonica. Model number CT-5365. The SSID and passcode are on the bottom. The back of the router has an aerial, on off switch, space for the AC, 4 yellow LAN sockets (one of which Im using right now) and the socket for the ADSL socket from the wall.
The front has the following lights from left to right: Power, WPS, WLAN, LAN 1, LAN 2, LAN 3, LAN 4, ADSL, Alarma. Under this, there are two small buttons, one with a Wi-Fi symbol, and one that says WPS. When I press the Wi-Fi I can get the Wi-Fi and WPS lights to light up, and when I press it again, they will go off. When I press the WPS button, nothing comes on, but also turns off the Wi-Fi and WPS light when they are on.
So this...is all the info I have.
Can ANYONE shed any light or offer any advice on getting this thing bloody connected? Would be worth at least 2 bags of cookies!!
Thanks guys!
Thanks guys!
