Can i use three M.2 NVMe drives with my z370 motherboard ?
Caporegime
27 Nov 2005
Guernsey
Guys i don't fully understand if my Z370 motherboard has enough lanes to be able to use three M.2 Nvme drives
My Motherbooard has 2 build in M.2 NVMe slots and i was hoping to also be able to add a third one by using an adaptor something like this
This is my motherboard https://rog.asus.com/uk/motherboards/rog-maximus/rog-maximus-x-formula-model/spec/
Would this work ? :confused:
If you use the second full length PCI-E slot, it appears to support bifurcation (4+4) * so you could use an adapter which has (or supports) 2x M.2 slots. Since this slot is close to the graphics card, you'd need to check it fits.
* This option would take 8 lanes from your graphics card.
The third full length PCI-E slot shares with the third 1 lane slot, which I believe you have to manually disable if you want more than 2 lanes (i.e. the full 4 lanes available).
This slot is close to onboard power buttons 'n stuff, so you'd have to check the adapter won't interfere with them, or vice versa.
