they do produce 400nm torque (295 ft lb)
as ive just posted above, the full 295 lb ft is only available briefly as an overboost feature on harsh acceleration. They are quoted at 265 lb ft.
that is also a great + to the tdci over the 220.Easy power increases,with almost zero decernable fuel economy drop.A simple remap with rail pressure upped,boost upped accordingly and combustion timings tweaked is all it takes.
The dual mass flywheel may spit out its dummy but the solid flywheel and clutch setup from the tranny will cure this and lower the 0-60 times as well,how do i know because i have physically done it!!
so you post factual inaccuracies, while passing yourself off as a "master technician"
when you're shotdown you then try and change your tune to " well they can be tuned well"
c'mon. Not exactly a great enterance to motors is it ?
