Can you prove that God does not exist?
18 Oct 2002
North
After reading recent forum posts about evolution, it always turns into God v science!
Who is right or wrong? It would be easier that God does not exist to some scientists. However science is forever changing, theory’s once set in stone are discovered to be wrong and changed. In same way, things in bible scientists and historians said were wrong are later proved correct! Who shall we trust in… an ever-changing science or a never changing God?
I don’t know a single person that does not believe in God… even the hardened atheist admits there’s something out there they cant explain!
Please can this not be some stupid christian bashing thread - only inteligent discusion please lol :D
neither is right or wrong, as you can't prove either, God does not rely on science so god cannot be proved or disproved,
Science on the other hand is only a model to fit known data and as such any theory's in science can not be proved 100%
I couldn't be bothered to read the other thread but...
Uhm, I don't believe in a god. Not being able to explain something isn't the same as thinking there is some higher intelligence/power at work.
I think your hoping for too much.
AcidHell2 said:
neither is right [or wrong], as you can't prove either, God does not rely on science so god cannot be proved or disproved,
I'll go along with that.
Burnsy
Errr.. right here.
That's what an atheist is, not kind of doesn't believe, just doesn't believe at all.
Can I prove God does not exist, isn't that like saying can I prove the center of the Earth is made of marshmallows?
Nothing can be proved beyond all doubt. We only dig far enough to gain sufficient evidence to make ourselves comfortable to believe certain things.
Thus it is trivial discussing "Can you prove X, Y and Z".
no, you can devise a test to prove what the centre is made of, namely dig down deep enough, there is no test that can be devised to prove or disprove god.
Drill down 3,500 miles? Past all the molten rock, goblins and wizards, since of course they could be below as well, until it's prove they aren't.
i do not believe in god. if there is something out there that i cannot explain, it is because i do not know enough about it, not because some imaginary thing is reason
it's still possible though isn't it? aI have described a method of determining the core. Enough money and it's totally possible to drill to that depth, it's not going to happen but it's certainly possible.
Where god, there is no test that can prove either way.
Vegetarian said:
What about alexanda the great, kingdom of Babylon and Blair then?
Dont you think God also uses Humans?
And your point is what exactly? Because "things happen" that somehow a invisible being planned it that way?
Rubbish. You make your own destiny.
I dont believe in any god, no god can tell a human what to do, who tells the animals to life a normal life, kill mate die, if you believe in a god you have to do what god says.
No god tells me what to do.
Also if there is a god who is the one, muslims, chritans, monks etc. ?????
off course you dont have to do what he says, that's the whole point of freedom of will, if you had to do what he said, we would be robots.
I don't have to. I also don't have to prove that the Flying Spaghetti Monster nor the Invisible Pink Unicorn exist.
Can you prove that he does?
Luke15 said:
Was a catholic. What's your point?
Not quite. It's like saying "I believe the centre of the Earth is made of Marshmallows"
No-one will take you seriously unless you can prove that you're right.
The scientists have better things to do than disprove random stuff that people make up all the time.
I think with hitler thing - there is a point.
For me to look at the Jews is proof of God - no other nation has endured so much yet is still here to this day.
In the Bible it has been prophicised many thousens of years before.... that Jews would lose isreal 2 times.... the 2nd time they would be dispersed to every nation and in later times a nation will hate them an try to kill them off but a reminent will survive and return to home to isreal!
