Hope i've explained this ok
I have just installed winxp64 on a seperate partition,however when i try to connect to the net,i'm getting nothing.
I'm connected using the onboard lan on my mobo & its showing in the device manager as marvel yukon 8010 pci gigabit ethernet controller,so that seems to be working ok
It's also showing as connected in the Network connections in the control panel as well
When i pull the cable from the modem it's seeing the cable is unplugged as well,so i figured everything seems to be working ,apart from no net access
What am i doing wrong here ? I don't really have a clue
Any help would be great
Rob
When i pull the cable from the modem it's seeing the cable is unplugged as well,so i figured everything seems to be working ,apart from no net accessWhat am i doing wrong here ? I don't really have a clue
Rob
I shall have to go & have a look
