1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Can’t screw into wall...how do I hang a clock?
Discussion in 'Home and Garden' started by dirtychinchilla, Jan 12, 2018.
  1. dirtychinchilla
    Sgarrista
    Ah OK, I’ve also used them a number of times, but in general I’ve found they wreck the wall a bit and that, for light stuff at least, it’s easier just to screw straight into the plasterboard.
  2. dholdi
    Wise Guy
    But aren't you fixing something heavy ?
  3. dirtychinchilla
    Sgarrista
    Not nornally
  4. godinman
    Those gripit things are great, I've attached a 50" TV using 4 of them, the blue ones are rated at like 200kg.
  5. dirtychinchilla
    Sgarrista
    You’re a very brave man. Did you clean the wall first? That was probably my error the first time round.
  6. godinman
  7. dirtychinchilla
    Sgarrista
    Ah sorry, I got mixed up. That’s what I’m going to get today, I think.
  8. Lakeland
    Mobster
    This. It will take longer than drilling but it’s a safe solution.
    Don’t be tempted to hamme through the last bit as it’ll just delaminate the board.
  9. dirtychinchilla
    Sgarrista
    In case anyone is interested, I used one of the yellow Gripit fixings. It worked perfectly.
    As far as my fear of screwing into a wire goes, I used a hand drill with a 15mm drill bit and took it very slowly. Worked perfectly.
    Thanks all for the advice.
  10. Caged
    Capodecina
    If your detector was throwing warnings all over the place is it because you might have foil-backed plasterboard?
  11. dirtychinchilla
    Sgarrista
    Yeah quite possibly. The outside walls seems to be 100% no go if you use the detector.
Share This Page
