only if it's pushing air out of the case, and I was meaning this thread:
http://forums.overclockers.co.uk/showthread.php?t=18356043
last off topic(ish) post
You are going to sort the cables out right?
No.
Not until I get the rest of it fixed....
And probably not after that either. Unless my case starts to melt. Then I may...
Lol
Seriously, it'll give it a much neater look. After my first build I had something that looked like that and after a few months I re did all the cables
What's wrong with HDD?
Fan error, just turn te fan monitoring off in the BIOS or plug a fan into the fan header on the mobo next to the CPU.
What's wrong with the power button?
I've set the fan to ignore but that didn't work
The HDD is detected in BIOS and in Device Manager, however it won't show up in My Computer so I can't save anything to it
Power button just refuses to work... Reset and HDD buttons are fine.
Re wire the power button on ur mobo.
Try formatting the HDD
I'll have a proper look tomorrow..ROFL at the sig.
All the details are in ur mobo manual![]()
it works, nice rig aswell, been preping my old nzxt case to do an i5 build fora friend
im not sure weather i can be bothered to log it, but ill build tomorrow
