Disconnect them all first then and then manage them
Yeah I will probably end up doing that...
Awesome pics and log mate..
I got that case, but Im havin trouble with the fan controller and temp readout
Good luck with the cabling!
Nice build, the CPU cooler seems the wrong way, which way is the rear fan blowing and the CPU cooler fan.
Cable management is a fine art! Took me well over an hour to sort mine out and that was with a modular PSU as you have to plan where each cable will run and where you'll hide it lol. Does make a difference on system temps though in smaller cases.
Yo mate, I have to ask, as you went for the same mobo ;
Have you had any issues installing the drivers? I can't get the newest BIOS for starters...
Thanks
Yes it is unfortunately, I just wasn't thinking about it's orientation when I was fitting it because it was so tricky and annoying to mount, so when it finally went on I just thought "Finally - im never touching that again!"
I don't think it will make too much difference though hopefully because of the intake fan on the side and exhaust right above it anyway?![]()
Only thing I was thinking is the CPU fan might be fighting against the rear extract fan, is possible to turn the CPU cooler fan around so it pulls air accross the cooler and straight out the rear extract fan
I know what's you mean regards fitting the CPU coolers, I lost count of cut fingers fitting certain coolers!![]()
Nice build in the Z9, but sort the spaghetti junction and it will look awesome!![]()
Cable managements a lot better- well done![]()
