- 7 Sep 2020
- Gods Country
Whats a good one out there to bring the paint back to life and shine.....
metallic....insigniaSolid black or metallic? How bad is the condition? What year and model car is it. Black is a very tough paint to deal with generally in my experience, if it’s bad you can get OK results by hand but you can get awesome results with a polishing machine.
by hand.....By hand or a machine?
whats clay the car??I’ve used this before as an all in one by hand it’s not too bad. Don’t expect miracles but will do an ok job. Ideally you would want to clay the car first.
Car Renewal & Restoration Range | Turtle Wax
Renew and restore your car with Turtle Wax. From scratch repair to headlight restoration, bring your vehicle back to like-new condition.www.turtlewax.co.uk
by hand.....
There's a massive detailing thread here somewhere, probably has loads of info in it.
A bit of hawk tuah and spit on that thang...should work, no?Whats a good one out there to bring the paint back to life and shine.....
Insignia has now been sold this morning.....picking up new to me, mercedes coupe on tuesday.
So will still need decent polish, wax, foam etc etc
For wax - Collinite 476 super double coat wax (physical wax) not water wax (end thread) , lasts ages and water beads right off, great shine, great protection and lasts about 4-5 months before you have to re-apply. After you have coated your car in it, for your follow on washes just use some PH netural snow foam and give it a once over with a jetwash, dont need to hand wash it. Great in the summer and winter, in the winter the water just beads up in to big balls and rolls off the car as soon as it hits the car
For polish - Merguiers ultimate compound
