Arite I've just started a new job that requires me to drive to leeds (from just outside manchester) and back everyday, its about 40 miles or so. I've currently got a V reg megane coupe which seems to be a bit of a love or hate type car but I've had it for over 2 years I think and for that time I was a student using it to drive home every now and then, to the supermarket everynow and then and then just odd drives etc. and I never had a problem with it, the common fault that goes wrong with these is the head gaskets blow and you have to get almost a new engine (new rebuild at least), at one point I had one, my mum had one, my mate had one and HIS mum had one, mad I know but all of them except mine blew their head gaskets in the space of about a year and cost over 500 quid to fix. Fortunately mine had this done about 300 miles before I bought it and its not happened to me again.
Anyway, it was perfectly fine bombing it around Leeds or home and the odd long drive but now its being put to constant use its useless, not suited whatsoever to long driving and I need to get something better,
I'd say with a weekends worth of work, I could probably get upwards of a grand for my coupe and even though I'm earning now, I do not want to spend a shed load on a new car and so I'm looking for cheap(er) options. Can anyone recommend anything? IObviously I've got a reasonable drive everyday so maybe a diesel and given that a large part of it is traffic I'd sacrifice speed for a little bit of comfort, I'd easily sacrifice performace etc. for some nice little comforts such as air con, remote central locking etc.
I was thinking a golf, maybe a yaris, something along those lines, what would you recommend, last time I asked I got some good opinions so please, fire away.
Cheers.
Cheers.
