Car stuck in a drain
Stuff waiting another 3 hours to get a 107 out of a collapsed drain. Can't you just get someone to turn up with a tow rope and pull you out? Or #tryharder?
Hell 4 or 5 people could probably lift up the front end of that thing by hand!
More like get 4 or 5 people to just push it out. Someone drive the wheels forward or back, which ever way you want to push it out
Jack the car up as high as it goes getting the front wheel up high. If you can get it high enough you could just push the car off the jack and it might be enough to clear the drain
Looks like its quite far in.
If you didnt care about the car id try and drive it out
If you care best thing is to lift it up to save sill/further damage underneath.
cars have 6 jacking points usually, one by each wheel ant one centrally front and back
It amazes that people cant solve these simple problems these days
Pfft easy! Just block the drain and flush the toilet multiple times, hey presto the stuck tyre will float to the surface and you can drive away with a string of soiled toilet tissue stuck to your car :p
Another easy way to get out... Get a mate to gently kiss bumpers with your car, and push it out...
Or pull it out.
Or lift it out.
So many possibilities.
