Carbide Air540 - Transplant & Upgrade
Finally got round to adding CPU to the water loop. Fixed that kinked tube with a right angle fitting, and added another 80mm fan to cool the HDD's (they sit below 30c now).
Some images...
I was going to ask about the CPU look as you had an H100i in the original build that I couldn't see in the finished pics! Great to see a 2 rad setup in that case. Going to ebay the H100 or got plans for it elsewhere?
I've already sold the H100i. The H100i is excellent for a hassle free water cooling solution, but the EK block takes it to the next level. As an example, stress testing the CPU with H100i would see its coolant temp sit around 36c. Under the same conditions, the EK block has water temp sitting at around 24c. The actual chip temp sits 10-15c cooler too.
Do you mind listing all the water cooling parts you have in here please?
I have been wanting to do something to my PC, thinking of watercooling depending on costs...
Just to give you idea, 24 x 10/13 Primochil rigid acrylic fittings + 2.7m of 10/13 blood red acrylic tube from Primochill. That alone cost me around 200£ and that is just a tip of an iceberg.
I still didn't buy angled fittings ( another 100-150£ ), blocks (250-300), pump/res (100), rads (150-200), fans (100-150).
My head !!!
