LoadsaMoney said:Yeah they need at least 20a on the 12v rail, i know mines only got 20a on the 12v rail, but it runs my x1800 fine as its a branded 520w PSU, depends if its only started happening since the x1800 was put in there, as you will get problems if the PSU cant feed enough power to the card as it could be trying to, id check your 12v rail, and it may not be a true 480w as some non branded PSU's claim to be, i know a 500w Q-tec is not actually 500w as its more like 2-300w.
x1800's are well power hungry, much more than the x8 series or the 6 series of cards.
Check the sticker on the side of the PSU, it should have 12+v & you want it 20A or higher (sometimes you can have 2 & then you can get away with lower Amps)CSA said:Sorry to sound like a idiot but ive never took much notice of PSU details , the downfall of many i predict
Whats a 12volt rail and how exactly do i check it ?![]()
ACESHIGH said:Check the sticker on the side of the PSU, it should have 12+v & you want it 20A or higher (sometimes you can have 2 & then you can get away with lower Amps)
), the Enermax Liberty 500w is known to be a good one, and will power it no trouble, and its only £72.
NNnnnmmnnn, that isn't always true m8, take this Enermax for example:Yeah if its got 2x 12v rails then you combine them, so if both 12v rails are say 18a, then a combined is 36a (doubled), so if you only need 20a for the card then you know thats fine as well.
