PinkFloyd said:Ok put a noisy fan in a Antec P180 and tell me its still quiet.![]()
messiah khan said:The p180 is no quieter than any other case. It is however very cramped and over engineered and has some nasty design flaws. The Eclipse62 or PC-7 would be better choices.
I had a P180 and got fed up about the noise i had to put up with! I ended up putting my rig in an 8 year old steel server case with massive sides you'd expect would resonate badly! In actual fact the PC is now whisper quiet with a couple more 38mm deep panaflo 120mm's!mnemonix said:Put that noisy fan in a PC-7 and a P180. Then tell me they'd make an equal amount of noise.
Yewen said:Just for the love of the case gods avoid the 830 like the plague.
Admiral Huddy said:Shame it looks a lovely case.
Looking for a decent new case to house an 8800GTX is not easy.. There's not much choice![]()
jaykay said:lots of people have had poor quality with panels not fitting etc
and for £150 odd you dont expect that plus the fan layout is crap all coolermaster have done is throw fans at the problem
