Case recommendation below £85 delivered
Well, I have now bought the case and was thinking if it was going to fit my 7950GX2 as it is massive and it has got problems with my current case. What do you guys know about this?
I am going to check what is the noise it generates and if its still quite bad I will change the 2 120mm fans for 2 Artic Cooling ones as they seem to be quite cheap.
Thanks for the helps though. I will provide pictures when I get this done (probable after xmas)
