I quite like the little extra's for the Luxe but at the price range the pro is probably one of the best. I do plan on replacing the 200mm fan at some point but would like to try it in there first and maybe limit the speed.
Does the pro have spcae for fans at the bottom front of the case?
sorry my mistake, mine is the Enthoo pro White....looks great
the 200mm is more like a low pressure Corsair fan, but the 140s at 90% speed are like a hurricane........but silent.
mine has two spaces on the base panel for twin 140s, but you'll need to remove that silly PSU cover, it makes the inside look too cramped anyway.
remove that and the Drive cages and you have a lot of space inside for cooling, the back of the mobo can hide 2 drives easily...... the top tray houses the fan speed controller
http://www.phanteksusa.com/products/phanteks-enthoo-pro-white
