Hey,
Thought I'd share my current project of transplanting the contents of my 800D into my new Caselabs S8. Basic aim is for minimal sound, less heat and looks
The current spec going into it will be:
CPU: 3930K @ 4.6
GPU: 780 Sli
Mobo: X79 Rampage IV Extreme
Ram: 16GB Corsair Plat.
HDD: 2x 250GB SSD 1x 1TB HDD
PSU: Corsair 850 (May swap out for something else)
Cooling:
EK Clean CPU Block
EK Clean FC GPU Blocks with Clear FC Plexi terminals
3x Alphacool XT45 360
Bitspower 250 Tube Res
D5 Pump with Bitspower pump top and mod kit.
Bitspower fittings
Corsair SP and AF fans @ 7v.
Mayhems White Pastel.
I will try and take as many photos as I can along the way but I do tend just to plough on and get it done.
Today's progress - managed to get the case put together and the rads installed so I could start planning my loop. I'll be using bitspower 16mm enhanced rigid fittings.
Currently waiting on my tubing to arrive, bending tools, new lights and a few more fittings.
CPU: 3930K @ 4.6
GPU: 780 Sli
Cooling:
EK Clean CPU Block
Bitspower fittings
decided to go with the extended top and slimmer rads to really clean up with space above the mobo so the larger tubing stands out without it being too cramped - that's the plan at least!
