Taking him for a drive and releasing him 100 miles away from home sounds like a good idea to me.
Have you had your cat Neutered.
sorry my bad, get someone you with a dog to take a dump in the area that should make the cat go away.It's been pointed out that it's not his moggy![]()
As mentioned earlier in the thread I can vouch for the effectiveness of citrus. I used 2/3 oranges worth of peel where my cat was relieving herself when we moved into our current place. She didn't do it again.
On a completely off topic note, I must admit I was massively impressed at the size of the log she dropped off behind the telly. Without a word of a lie it was the size of a human turd, took a picture of it and everything.
Make a 10,000 volt catdeteringawesomemadeofwin machine, with just a relay and a transformer out of an old radio that works off the mains.
Wire the relay up so it oscillates on and off quickly, wire the LV end of the transformer up to the same connections used to power the relay, and boom! 200 or 300Hz of 10,000v pulses.
Simply run fine wires across your lawn, or just shove terminals into the ground connected to the transformer's HV end.
Job solved!
*No responsibility is taken for any children or animals fried, toasted or otherwise affected by the above.
