i hope the 9.1' give a nice boost like the 8.12's did![]()
( i hope)Only running late as they probably had a mountain of probs off the 8.12's, namely the code 43 error.![]()
Myabe they're actually fixing some of the HDMI bugs when using their cards in an HTPC. Pigs might fly too.
What specific bugs?
Makes me think of The Beatles - Number 9 or whatever it was called on the White Album.
Yes they often lose sync with the amp if you put your computer into standby, which causes windows to restart when you try to resume. Also if you change inputs on the amp while your HTPC is on, then switch back it gives you a blank screen. There are big incompatibilities with certain amps too such that it won't work at all without a huge amount of fiddling. Many can only get 2 channel sound instead of 6-8 channel.
And a few others I've probably forgotten about.
Ive heard rumours that the 9.1's will be labelled "8.561.3" ?
