Central Heating Help Needed
Wow, sorry to be causing an argument on the forums.
Don't worry about it. I'd be more surprised if this thread didn't cause and argument. Every thread of significance in General Discussion causes a difference of opinions to be aired. It's nothing to do with you :)
I am "hoping" to do it cheap, as I have no money lol. But, not "trying" to do it cheap. If its broke and needs replacing, then I will just have to get saving!
If it works, it works. Shelling out on a new boiler may take many years to realise savings from increased efficiency so it depends how long you plan to stay in your new place.
I would say regardless of whether you get it working yourself getting the fire/boiler serviced is a must. With them not being sealed units and sharing air with the room they could poison you with carbon monoxide if there is a fault. Considering the last owners didn't even know it was there I doubt they ever had it inspected!
Also get yourself a carbon monoxide detector.
OP - have you established if water is flowing through the pump yet?
It is probably time to get the experts in - just try and ensure they come recommended from someone you know if possible.
Hey sorry to hear you're having a few problems. one thing to try is giving The Building Centre a call, thy are a building firm specialising in ALL building products problems etc and can help you no doubt. their number is 020 7692 4000 give them a ring and ask for the information department whoever answers will help:)
You certainly need to get someone to come and inspect the back boiler!
As Fourstar said, given that the previous owners didn't know about it, i doubt it's been serviced for a long time and is therefore a potential risk to your life.
You seem to have all the parts required for a heating system, albeit pretty old parts, so I would suggest that you do some research into how central heating and hot water systems work so that you know what is supposed to be happening. The concepts are pretty straight forward, and there is a lot of information out there but it takes some wading through to find it. This site http://www.miketheboilerman.com/how.htm seems to give a quick synopsis of what you need to know so that you can understand your system, but you will need to google for some decent images of the different types of systems. (There are some great sites out there but I'm having Googlefail today and can't find anything!)
Have a look for water tanks in the loft. You may have two tanks up there, one supplying water to your hot water cylinder for hot water from the taps, and the other supplying water to your boiler to heat the radiators and the hot water cylinder. I really think it would benefit you to get your head around your system and how it SHOULD work so you have a chance of fault finding it.
And again, please get someone in to service the boiler asap, then you can also ask them about your whole heating system with some knowledge to understand what you are being told :)
I am arranging for someone to come in and service the boiler. Fingers crossed!
As for the water tank, yes, I have 2 tanks in the loft - a big one where the hot water comes from and a smaller one.. that presumably must be for the heating. I can not hear anything from it when you turn the system on, and I cant hear any water flowing anywhere. I'll have a look at the link you sent.
Thanks, yet again!
OP - Where are you located?
Kidde 0122UK Dual Smoke and Carbon Monoxide Alarm £16.99 @ the rain forest website!
£16.99
This is a must purchase if you have nothing of the sort :) Protect yourself from what is essentially an invisible killer
the part on ebay is what controles the boilers temp.. its the same thing he has took a pic of, that white nob is his boiler thermostat.
http://www.ebay.co.uk/itm/BAXI-BERM...arden_Hearing_Cooling_Air&hash=item27b5f9d63a
his room thermostat controles central heating and his cylinder thermostat controles his hot water..
hope ive cleared up what ive been trying to point out..
Thanks, yet again!
if you run your hot water for a while the bigger tank should start to fill up as it emptys its self.. the smaller one never fills once all the radiators are full of water.. like ive said, make sure they're full of water..
No, he hasn't taken a picture of the actual air temp thermostat at all. There is a boiler stat picture nothing to do with what I or most people would class as the central heating thermostat :rolleyes:
Or perhaps you're referring to what you believe to be a thermostat which is actually a timer.
He STATES he's found the thermostat, but there is no picture.
Further thought - The thermostat for your central heating - Have you located it?
i'd like to point out again that you asked him if he had located the boilers thermostat and not his room thermostat, at that i made a point that he had took a picture of it.. hopefully you can see from my above post that i am indeed right and you're getting mixed up..
This, Maybe Mickie was the original plumber.
maybe i did your mother
Let us know how you get on with the gas man op!
Mickie are you seriously 29? Mother comments are a little hormonal teenager.
I can't unfortunately see that you're right as you aren't. Nevermind - open your eyes I never mentioned boiler thermostat. Read what you have just quoted.
Cheers and gone.
The plumber you got in sounds like a complete waste of space. £30 to change a pump... are you sure he even changed it because they cost something like £80-90 and then he'd surely charge labour on top...
