CF 5770 problem
Permabanned
22 Mar 2008
Redditch
Right just installed two new XFX 5770's in CF on windows 7 64bit.
I have looked in device manager and i have an exclamation mark next to it.
Ive right clicked and gone to device property's and it says 'This device cannot start. (Code 10) ' and ' This device isnt using any resources because it has a problem ' Anyone had this issue before?
Which drivers should i use for CF 5770? ive tried 10.5 but they crashed my system and made it fail to load to windows every time.
No one?
Just tried to install the P5Q pro chipset drivers and its saying i cant because it doesn't support 64bit :/
also cant install new drivers because its telling me the cards arent installed :(
use the drivers for the mobo off of the driverdisk that came with the mobo , also full system specs and drivers you have installed would be more of a help for us to try and help you
I have put the disk into the pc and tried to run but i get an error saying the dvd drivers on the dvd dont support the version of windows im using
Im using Windows 7 64bit
Intel q6600 @ stock
Asus P5Q pro
4GB 2 x 2GB DDR2 Kingston 8500 memory
2 x XFX 5770 1GB in CF
1TB Samsung spinpoint F3
So far ive tried all drivers from the asus website but get an error when trying to install them, the error saying they dont support 64bit operating systems
tried 10.1,2,3,4 and 5 ati drivers and all of them are making my system hang upon restarting
Mmmmmmm, doesnt support 64bit, I have Vista 64 on a P5Q Pro with Xfire Powercolor 5770's with no issues so I do not think it is the mobo.
Have you tried the latest drivers from the Asus site, or even the intel site? I had that board a while and never had any driver issues with Win 7 64.
Yep tried both.
Get the error everytime i try and install any driver, tells me its not compatible with Windowd 7 64
Whats the best way to installl an OS with CF?
shall i format with just 1 card in and then add the second?
Or can i format with both cards in?
Have you tried 1 card at a time maybe one is faulty ?
I've had 2 in CF on a P35 and X48 chipsets on windows 7 64 with no problems.
Try right clicking it in device manager and reinstalling the driver ?
I have tried both on their own and both are fine, theres just something conflicting when i CF them
tried updating the drivers and my system just hangs
I had 5770 CF on my P5Q Deluxe, no issues whatsoever.
Have you tried to install the drivers that came with the cards (cd)?
Maybe they are not pressed very well into the PCI-e?
Does the power to each card is coming straight from the PSU, WITHOUT other devices on the same cable taking power?
Did you wiped out previous gfx cards device drivers (with the OLD card on), before you install the cards and the Catalysts?
It was all from a fresh install onto a brand new unused HDD
Its a modular psu so each 6pin pci-e cable has its own port to connect to
Im using just 1 card now and everything is perfect and the same with the second card
but when i add them together i get all sorts of problems
