I'd just do it with one until you know for sure it's OK with two. I can only see it causing problems, and there's no reason why you can't add it later. The sensible thing to do would be to install with one and see if you can get the system up and running sweet, then try the other one. It should be as easy as the drivers installing on bootup and checking the crossfire button in CCC from what I understand.
and my idle temps are 30
