Change Location?
10 Feb 2013
West London
So there is a game that is in soft launch only in Netherlands and Canada and i live in the UK, I downloaded a vpn and change my location to Canada and then i force stopped the play store and cleared the cache and data then when i opened it i searched for the app but it didnt come up so i went on the fb page and clicked a link to the play store and when i click install i have to log in and then it says its not available in your country even though I'm running a vpn. Does anyone have some tips, Cheers
You can try getting a Canada play store ID or the gmail one and then try with a VPN unless your VPN is not having IP leak issues.
