You spec'd an OEM bluray drive which means it's probably not going to come with playback software and a sata cable.
I've been reading up on these new intel processors after seeing they aren't as straight forward to pick like the only pentium 4 days.
For the sake of £50 would it be worth upgrading to an i7-3770 ivybridge?
http://www.overclockers.co.uk/showproduct.php?prodid=CP-405-IN&groupid=701&catid=6&subcat=
The buying has begun, just bought the Zalman Z9 plus off No LINKS for a whopping £26 brand new![]()
Best of removing the competitor link before a Mod spots it, as it is against forum rules. Just a friendly warning.
But, well done on getting a bargain.![]()
Yeah i'm pretty chuffed with the saving, seems to be some bargains out there if you dig deep enough![]()
