Changing components for order
Also 99% sure
If youre going down this route you may as well get the HAF X for a little bit more, however a HAF X (or 932) and H70 are a lot more than your original budget, if youre fine with that then go for it, as I said before though if youre wanting to stick to budget the Scout Storm and Titan Fenrir are a good combo
Also 99% sure
start a thread asking that specific question....i think it would be fine but would hate to say for sure and its not......im 99.9% sure it will fit by a mile though as its a decent size quality case
Thanks for your help guys. I have made a thread just to see if people can come up with a few reasons to see if it really is worth bankrupting myself for the HAF X/932 with the H70.
i checked with corsair forum and it definatley fits :D..... i wouldnt bankrupt yourself for anything.....its a great case and cooler but there are cheaper like everything so at the end of the day hendar its your call....make the decision that you know is right :)
How long is the 6950 and are the power sockets on the end of the card or the top? The Scout is only a "midi" tower and not a full tower and only has 10.5" between the rear of the case and the hdd cage. If that 6950 is close to 10.5" then it will be a squeeze to get the power plugs in if they are on the end of the card.
Don't get me wrong, the Scout is a good case. I have one and rate it better than my Lian-Li PC-P50. It's just a bit tight for larger cards.
Well the 6950 is 10.8 inches long so i guess that rules the scout out then :S
I have the phantom :)
As you can see in my sig, I like it rather a lot ;) it is quite simply the best case I have ever used, and would recommend it. But it won't work with a h70, unless the new revision is out
Hope this helps :)
I noticed the H70 problem! what a pain in the backside. I guess I will have to go for the HAF 932/X or maybe the Silverstone Raven 02
