FishThrower said:wont you need to press on the brake pedel a lot harder if you do that? the higher gear you are, on lower revs the harder it is to stop, wont you just be wrecking your brake pads?
I always change from 5-4-3 if i want to get into 3rd, I sometimes go from 4th to 2nd tho
Brake pads are cheap, clutches and gearboxes aren't
