brendy said:For what its worth, the 20vt VAG engine can easily pull away from the steepest of hills on the bite point, it just keeps raising revs until it goes.
TomTomTom said:NO. Not move-the-car... just to hold the car in place long enough to get to the gas pedal.. lol
TomTomTom said:again yes I know about hand-brake on extreme hills.
TomTomTom said:Well this is a surprise to me. It's what they teach in driving school and like I;ve repeated it's what I've always done. And for anyone else catching up, again yes I know about hand-brake on extreme hills.
Anyway, thanks everyone![]()
it's worked on all other manuals I driven just fine. you'll even find that technique in a driving manual
TomTomTom said:But those who don't have really underpowered cars or a lot of machanical sympathy... just try it before you knock it.
It's pretty neat and it doesn't eat the clutch any more than moving off, probably less if you don't hold position for too long.
it has no problem doing it when the rpm's haven't dropped by the 300 rpm amount. And other non-diesel cars I've driven have also done it just fine.alexthecheese said:Fair enough if you've got a huge engine-d car or a diesel, but you've got a 2.0 Mazda.
I know that. I do that too.alexthecheese said:Most people don't actually use the handbrake on a hill-start anyway - off the brake and straight onto throttle/clutch and the biting point will get you underway quite happily.
Thanks for the warning, but I've never heard of this technique being a no-no. Different strokes in the UK.alexthecheese said:And TBH if you went to a garage about this I think you'd get a few smirks.
TomTomTom said:BTW, I think some people mistunderstood "cooling fan" for the A/C. I meant the cooling fan on the rad..
TomTomTom said:Well I fail to understand how doing this wears the clutch more than regular moving off or for that matter doing a hill start with the quick-footed method. If you've never done it yourself, you're probably imagining something brutal... it's very quiet, uneventful and smooth when you do it.
Le_Petit_Lapin said:Tried it on the way to work this morning.....and bugger me....it actually works, as long as I bring up the clutch slowly.![]()
volospian said:Isn't the OP just talking about effectively "holding the car on the clutch" like when you are at a junction on a hill and you are waiting for a car to pass before pulling out?
As volospian said, it's only to hold the car while you move your right foot from the brake to the gas. Once you're on the gas it'll feel a little different from your usual moving off since your clutch is already part way up... you might chug a little the first time you try it.Le_Petit_Lapin said:Tried it on the way to work this morning.....and bugger me....it actually works, as long as I bring up the clutch slowly.![]()
Just found a steep sloped side-street, stopped at the bottom, stuck the car in first and lifted slowly, it make a little grumble when the clutch was 1/2 way up, but then went on to creep all the way up to the top, without me touching the accellerator pedal. Slowly admittedly, but it did do it.
