Changing the bulb in an e36 328i's OBC
Caporegime
25 Nov 2004
On the road....
Is it particularly difficult?
Mine seems to have packed up (half the display is dark but still readable) my Google skills seems to have failed me, anybody got any previous on this?
Ta. :)
Not difficult at all.
Feel in the cubby hole under the OBC for a hole that allows you to get a finger behind the OBC and push it out.
Bulbs are then twist out, 3 of them on the top of the unit.
Cheers guys - I did not want to start pulling it to bits & inevitably break something.... :o
Halfrauds for a replacement I'm guessing?
Ahh! true to form, sourced some bulbs, pulled the thing out and now on its re-assembly, it won't work at all.
:o :D
