Check my spec please!
10 Jan 2006
W. London
Hey there guys, well its time to build my first ever pc w00t! (I won't be saying that if anything goes wrong! :p )
Anyway this is what I've chosen...
CP-128-IN Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (CP-128-IN)
£214.95 £214.95
MB-152-AS Asus P5W DH Deluxe WiFi (Socket 775) PCI-Express DDR2 Motherboard (MB-152-AS)
£149.95 £149.95
MY-013-GS G.Skill 2GB DDR2 HZ PC2-6400 (2x1GB) CAS4 Dual Channel Kit (F2-6400PHU2-2GBHZ) (MY-013-GS)
£147.95 £147.95
GX-112-SP Sapphire ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-112-SP)
£219.95 £219.95
HD-079-SE Seagate Barracuda 7200.10 250GB ST3250620AS SATA-II 16MB Cache - OEM (HD-079-SE)
£52.50 £52.50
CD-078-SA Samsung SH-S182D 18x18 DVD±RW ReWriter (Black) (CD-078-SA)
£21.95 £21.95
HS-007-TT Thermaltake Big Typhoon 4 in 1 Heatpipe (Socket 939/754/775/478) CPU Cooler (CL-P0114) (HS-007-TT)
£24.95 £24.95
SY-008-ZA Zalman VF900-CU Quiet Copper VGA Cooler (SY-008-ZA)
£20.95 £20.95
CA-005-AK Akasa Eclipse 62 Aluminium Case (CA-005-AK)
£69.95 £69.95
CA-025-EN Enermax Liberty 500W ELT500AWT ATX2.2 Modular SLI Compliant PSU (CA-025-EN)
£59.95 £59.95
FG-024-AK Akasa AK-183-L2B Amber Ultra Quiet 120mm Fan - 3 pin (FG-024-AK)
£9.95 £19.90
AC-000-AC Arctic Silver 5 Thermal Compound (3.5g) (AC-000-AC)
£5.95 £5.95
KB-015-SK Saitek PZ30AU Eclipse Illuminated Keyboard - Blue (KB-015-SK)
£24.95 £24.95
KB-013-RA Razer Diamondback Plasma 1600dpi Gaming Mouse Limited Edition - Retail (KB-013-RA)
£29.95 £29.95
GS-001-IC Icemat - Black 2nd Edition (GS-001-IC)
£16.70 £16.70
Subtotal £1,080.50
VAT £189.09
Total £1,269.59
I already have a 200W6CS Philips monitor so yeah... What do you think guys?
great spec mate... let me know how the keyboard pans out for you... I'm thinking about getting one of them as well :)
Stelly
Cool, thanks mate was hoping for a reply from you! :D Will let you know about the keyboard sure. :)
I think i'm pretty set on this spec, have been researching and reading etc... Lets see what other people say :p
Ah shucks :)
Also those Akasa Ambers are deadly quiet... have 5 or 6 (lost count) installed on my computer and I only get a slight humming... I would consider partitioning your spinpoint, for the OS and the gaming unless you have a HDD already at home, and if your willing to splash out a little mybe go for a Raptor 36Gb just for the OS, but thats just my spending streak in me coming out, but that spec is turely really good
Stelly
Yeah this pc will be for gaming mainly so i'll make a partition for the OS and leave the rest for gaming. Work etc is done on another pc. For the OS what do you recommend? XP Pro or XP Pro 64bit?
I love the spec wish I could spend that much for a PC.
Let me know how the keyboard and mouse mat are thinking of getting them both.
I have 1 thing to say to you - Your first build, lot of money DONT **** IT UP
EDIT
XP 64 wouldnt make much of a difference on that spec. So save a bit of money and go for XP Pro
Just normal Windows XP Pro... as your going dual core, and did you know that home edition does not support multicore... if I remember right... little trivia for you there... I dont think Windows XP 64bit is worth it since by the time you will really need a 64bit OS Vista will be fully out and kicking!!!
Yer if you need any help with the build at all please let me know :)
Stelly
Will do mate :) And I won't mess it up! (Hopefully!) I'll do it calmly and smoothly :p and it's going to get cooler soon so yay!
Yeah good luck. I whish it would cool down my PC keep restarting because I don't turn fans up because they make too much noise.
Oh make sure to get a good Fan COntroler and templ monitor.
You going to be OCing it?
Stelly
Ah right thanks Stelly, XP Pro it is then :p. Was 80% (very accurate :p ) sure that i should use XP pro as the OS. Thanks mate
Yeah mate, hope to do so. That's why Im getting the Thermaltake BT and the Zalman VGA cooler. Found out that changing the cooler on the graphics card will void the warranty :o So im going to use it for a bit and then if it's all fine and dandy, i'll change the VGA cooler to the Zalman
One of the reasons I went for a custom water cooling setup :)
Stelly
Beenom please do realise that the moment you take off the standard VGA cooler on your ATI gfx card you invalidate the warrenty
Stelly
Yeah I know :( . Thats why im going to keep it at stock for a while and make sure that there are no problems with it. And when i'm confident that it's all fine, i'll put the new cooler on.
:eek: Thats another thing I didnt think about when I took off the cooler!!! :(
Stelly
:p Im sure it'll be fine though :). They don't have the menacingly high death rate as the 7900GT? I think it is ;). It'll be fine mate :)
Well if I come on here crying tonight you know why... btw add me to msn my addy is stel_26 @ hotmail.com
Stelly
Stelly
XP Home will do (unless you use/need this)!
What Home doesn't support is multiple processors, i.e. mobo's which take 2 processors or more (if any). A Dual-Core CPU is considered as 1 processor :mad:
EDIT:
Multi-core (computing) said:
Another issue is the question of software licensing for multi-core CPUs. Typically enterprise server software is licensed "per processor". In the past a CPU was a processor (and moreover most computers had only one CPU) and there was no ambiguity. Now there is the possibility of counting cores as processors and charging a customer for two licenses when they use a dual-core CPU. However, the trend seems to be counting dual-core chips as a single processor as Microsoft, Intel, and AMD support this view. Oracle counts AMD and Intel dual-core CPUs as a single processor but has other numbers for other types. IBM, HP and Microsoft count a multi-chip module as multiple processors. If multi-chip modules counted as one processor then CPU makers would have an incentive to make large expensive multi-chip modules so their customers saved on software licensing. So it seems that the industry is slowly heading towards counting each die (see Integrated circuit) as a processor, no matter how many cores each die has. Intel has released Paxville which is really a multi-chip module but Intel is calling it a dual-core. It is not clear yet how licensing will work for Paxville. This is an unresolved and thorny issue for software companies and customers.
Beenom, spec looks sweet! Hope you enjoy the build (& also make sure you read the manual/s & have them by your side) :D
Software wise, 'invest' in this two:
Very useful & both have literally saved my behind on several occasions :o
The only thing that attracts me is the remote desktop thing, but then you can use any freeware software for that! So XP Home or Pro hmm will decide later! Also thanks for the software suggestions, I'll "invest" in them now ;) :p
