- 7 Apr 2017
Didn't the prototype of this outperform custom loops when tested?
It did better than an AIO by a couple of degrees but with a stupidly high fan volume and speed. At noise normalised speeds it was worse IIRC
Aah right, I just recall one of the tech tubers using the giant prototype but im sure fans were either silent or off and it was performing better than aio's and custom loops...
Aah right, I just recall one of the tech tubers using the giant prototype but im sure fans were either silent or off and it was performing better than aio's and custom loops... then again I have a memory like a sieve...
so basically if you crank up your fans on your aio it will be same?It did better than an AIO by a couple of degrees but with a stupidly high fan volume and speed. At noise normalised speeds it was worse IIRC
Linus tech tips apparently can't afford to replace the TR4 AIO that broke months ago
I spy with my beady eyes...
A quad fan cooler put up against a single fan cooler.
The Liqtech? That model is known to be faulty. Gamers Nexus did a couple of pieces on it.
So what? That single fan cooler beat out other multi-fan coolers. Did you watch the video? He said that you should only buy this cooler if you have a Threadripper CPU.
I'm thinking to myself that a 240 rad AIO with a TR4 plate and quad fans would have been the correct comparison and cost less too.
Did you actually read my post or just stop at that line?
Yes. There's only one (unless you DIY) and that's the Liqtech.
Except that's not true. I could get a not-liqtech delivered tomorrow.
Nah its a different design.
