- 8 Jun 2018
There have been a lot of reports coming out that people having melted connectors. Be it both from the cable and gpu. Or from either the gpu or the cable.
I am not sure if anyone here knows who JonnyGuru is but he's a respected PSU expert. JonnyGuru is the PSU as Kingpin is to EVGA Video Cards.
I believe he's working for Corsair's PSU division now. And, apparently these melting connectors were well known.
The worst way to bend the cables is horizontally. Although vertically is can also be bad. Horizontal bends comes when you pull the cable to the gpu from the top down. Or when you vertically mount the GPU.
Here is an example of a vertical mounted video card. With the cables on top of the GPU. Notice that the cables are bending horizontally.
Here is a bend that is vertical. Look at how sharp this bend is. Notice this was done because it was the only way to close the side panel to the case.
This is how the cables look. Bent horizontally.
This is what happened after using them. Still in the same orientation as out of the box.
The above pic is showing how 1 particular cable in the middle looks hotter then the others. Notice the bend.
Here you can see what the temps are like using the adapter. And yes, that's hot.
TO ANYONE WHO HAS HAD A 4090 FOR AT LEAST 1 WEEK:
Check your cable connector and your gpu connector to see if there are any early warning signs of melting. Also check to see any discoloration, issues, etc with the pins themselves. Even though you don't see smoke. Try to smell the connects to confirm. It is almost impossible to use these cables without bending them inside of your case.
