Chem trails and con trails, What's really going on ?
The ability to think critically and not brush everything off as BS and call everyone a nutjob is the sign of an inquisitive nature.
Believing everything you are told like a good little robot is the sign of an idiot.
Also anyone noticed something ? Whenever someone brings something like this up that person, Me in this instance, Is usually attacked, Called names and then made fun of, Weird that isn't it.
Ummm because you're not being rational, theres zero evidence to support anything you said in the op.
Jet aircraft don't leave any visible trails at all. Not chemtrails, contrails, water vapour of any of that crap.
But if you aren't in the know you'd be forgiven for thinking those those trails are made by the engines.
So you wouldn't figure out that we're not making those trails in the sky at all. It's not human technology. You see, every time an alien vessel wants to fly somewhere, they basically fly directly behind a jet passenger plane. The pilots and the passengers can't see them, because there are no windows pointing backwards. And they paint the underside sky blue, so we can't detect them either.
But whilst they can stop their craft being seen in this way, they have no way to disguise the plasma being exhausted from their cold fusion reacting drives. So they fly next to a jet engine. And conveniently there are the same number of alien craft as there are passenger flights. Would be awkward otherwise.
Now you know.
Now you know.
Rep +1
Quoted for truth ... I knew it, I just knew it !!!!!
Thinking critically if these are chemicals and they're affecting people swabbing any surface in a flight path should give you the chemical.
Anyway though dicehunter/any other chemtrail theorists where exactly do you think the tens (hundreds?) Of tons of chemicals are held to make these trails are stored on the aircraft and where they are dumped from?
Cause for any airbus model I'll go have a look anywhere on the wings you like.
But i certainly dont ever remeber fitting the "secret chemical dumping sustem" on any plane so far
Most conspiricies can be discounted simply by the staggering number people that would have to be in on it without saying anything.
Careful OP, they don't want you finding out - they will throw you into a burlap sack and rocket you to space to be sent to the Moon (which is a penal colony for dissidents).
You're clearly just in on it all and part of the plot. :p
Lol, ROFL, never seen that before
This doesn't seem so far fetched.
The U.S Congress Research Service are currently looking at various ways currently to manipulate the atmosphere.
Here is the document from 2023.
If there are documents already about it then who knows what is actually happening.
One thing I have thought about
To conspiracy theorists, if global warming is a myth then believing in Chemtrails would be silly, there would be no need to do it right?
Stratospheric Aerosol Injection (SAI)
SAI as an SG method would require the dispersion of sulfates in the stratosphere to createmanmade aerosol particles in order to make the atmosphere more reflective to incoming solarradiation energy and mimic the cooling effect observed after a large volcanic eruption.20A varietyof methods have been proposed to add sulfates to the atmosphere, including “aircraft, rockets,artillery, and pipes elevated to high altitudes carrying aerosol precursors.”21
Marine Cloud Brightening (MCB)
The MCB technique would involve spraying a mist of submicrometer seawater particles intomarine stratocumulus clouds.36 The spray particles would form small droplets within the cloud;these droplets would increase the cloud’s reflectivity, increasing the amount of incoming solarenergy reflected back out into space
Cirrus Cloud Thinning (CCT)
CCT would involve adding an aerosol of insoluble particles to the cloud, whichwould form larger crystals than the smaller ice-only crystals. These larger crystals would fall outof the atmosphere more quickly than the naturally forming ice-only crystals, thus thinning thecirrus cloud and allowing more heat energy to escape.4
It isn't far fetched, what's far fetched are the idiots who think the chem trails are for mind altering purposes on the public below.
IIRC there have been attempts to "manipulate the atmosphere" for decades, I think the Soviets and Chinese have played around with trying to get rain to fall "early" so that it didn't rain on high profile events for years.
From memory they basically put out some kind of dust that the moisture adheres to thus becoming a water droplet rather than vapour and thus falls.
I was trying to find another experiment which was carried out around that era which accidentally resulted in toxic particles being spread over parts of the south coast but I can't remember specific details to find it.
Thread necro after 8 years for this? Rather than searching for an existing conspiracy theory post to latch onto, why not start your own thread?
Doubtless actual weather experiments do sometimes take place. But that does not mean that all aeroplanes are leaving visible trails because they are filling the skies with countless tons of secret chemicals every day...
