And how are you going to match the fueling to the modified engine?
If worse comes to the worse, you can just stick the cams in on the stock ECU, it will be perfectly safe, just won't reach maximum power from the cams.
Why's that? Running lean perhaps?
And I don't see how an ECU designed for a 2.0L engine will also correctly fuel a 1.8L engine in the same state of tune. Bit pointless spending time and money if you end up with half a job. The ideal OEM ECU would be one from the 130bhp Escort, except the PATS imobiliser is not compatible.
