- 13 Dec 2022
- North West
Heyo,
Apologies if this is in the wrong place. Wasn't sure where to throw this.
Currently running:
Asus Rog Strix x570-F Gaming
Ryzen 5900x
RX 7900 xtx
For the last few months, I have been experiencing completely random crashes. The computer would "choke" out, then a black screen. Seemingly out of nowhere. I thought it was probably the GPU, I also wanted a new GPU at the time so I grabbed the new card. Lo and behold it crashes still!
It wasn't until today I managed to sit down and really dig for the issue, for the last few days I have been running core-cycler and OCCT, just trying different loads to test for stability. Everything was fine... I loaded up Cyperpunk for a few hours, and it crashed. To restart I had to hold down the power button, I started instantly and it started a black screen. I loaded up HWInfo and watched my GPU and Chipset temps. GPU got toasty, 100c memory junction, 80c "gpu temp", other temps on it in the 90s. My chipset however, 113.8c. Which seems rather high.
I restarted and repeated twice, both times it crashed with a chipset temp of 113.8. So, pretty convinced that is the issue. Now, does anyone know what I should do? It seems to be exacerbated by the new GPU. I have grabbed a couple new fans to replace the top fans to push more air out of the case. I am wondering if perhaps I should consider it as a motherboard fault. Super lost and not sure what to do!
Still have some issues with 7900 xtx, but can't super test it as this issue is in my way.
Currently running:
Ryzen 5900x
RX 7900 xtx
